AUDIO ONLY
Hi,
I have recently installed the Advanced Codecs 8.5.7 to watch MKV files through WMP on my TV. The older MKV files will play but the newer format MKV files only have audio and no video. To watch these files I have been converting them to other formats using Any Audio Converter. Even when I convert the MKV to MKV(must be older format) it plays perfectly.
Can you help me solve this issue??
Thanks,
booga47
press [Reset All]
select the SUGGESTED settings checkbox
choose to disable Media Foundation for the specific filetype on the MKV TAB
[x] disable Media Foundation for MKV
