DTS/Dolby audio with WMC7 stuttery/popping
05-22-2012, 05:27 PM
Hi,
I really hope someone can help. I have DTS and Dolby setup via the SPDIF cable to a Yamaha receiver. When playing an MKV with DTS audio the receiver switches to DTS (or Dolby if it's Dolby) but every few seconds to few minutes I get stuttery/poppy sound. I have gone through all the setup guides I can find but can't for the life of figure out what the hell is wrong. It is also not a network issue (I am streaming from a server to my Media Center system) as I get the same issue when playing a file locally with either Media Play or Media Center. Please help, I really want my digital audio working properly. Thanks in advance |
05-22-2012, 05:32 PM
RE: DTS/Dolby audio with WMC7 stuttery/popping
Make this selection on the audio tab.
The leftside speaker config is automated - let it be. 'Same as Input' is correct for these type of output |
05-22-2012, 05:53 PM
| RE: DTS/Dolby audio with WMC7 stuttery/popping | |||
05-22-2012, 06:00 PM
Control Panel | Sound
set the speaker config of the active device to 'stereo' |
05-23-2012, 07:35 PM
Post: #5
(05-22-2012 06:00 PM)Shark007 Wrote: Control Panel | Sound Hi again Shark, I tried to go to the Sound Card config in Sound but the option "Configure" is grey out. I also don't know if maybe this has something to do with the device as it says S/PDIF passthrough when I am looking in the control panel applet Sound rather than just S/PDIF. Do you thing it could be the sound card itself? There is onboard sound with the MB (only coax) and when clicking that sound device I can click the configure option. Do you think it is worth buying a coax cable and using the onboard sound? dAos |
05-24-2012, 06:23 AM
Post: #6
in Control Panel | Sound, 1st, click on (select) the device with green arrow
then [Configure] button should become available |
05-28-2012, 06:41 PM
Post: #7
(05-24-2012 06:23 AM)Shark007 Wrote: in Control Panel | Sound, 1st, click on (select) the device with green arrow I have checked that setting as I stated above and the Configure option IS GREYED OUT. I will attach a screen shot tonight when I am home again. Another thing I found is that Dolby is fine with Live TV, the receiver switches to Dolby Digital and there is no popping or stuttering. This issue is only occurring with mkv's with DTS or Dolby audio. Any other suggestions cause I am sick of playing with settings.
05-29-2012, 01:38 AM
Post: #8
(05-28-2012 06:41 PM)daos Wrote:(05-24-2012 06:23 AM)Shark007 Wrote: in Control Panel | Sound, 1st, click on (select) the device with green arrow Hi Shark, This is the screen shot of what I get when I got to Control Panel | Sound. As stated above I can't configure the device as the option is greyed out. Any help would be appreciated dAos |
05-30-2012, 04:50 PM
Post: #9
(05-29-2012 01:38 AM)daos Wrote:(05-28-2012 06:41 PM)daos Wrote:(05-24-2012 06:23 AM)Shark007 Wrote: in Control Panel | Sound, 1st, click on (select) the device with green arrow Hi Shark, Any suggestions on what I can try next? I have tried a BlueRay disk with the same result. I was thinking it may have been the rip but that does not appear to be the case. Thanks dAos |
05-30-2012, 05:57 PM
Post: #10
The audio drivers may have installed its own control panel.
check the startmenu for something 'asus' or 'xonar' |
