Error installing MPC BE MadVR, happens both 32bit and 64bit
Recently, when I try to install MPC BE MadVR version on fresh installs of 64bit Windows 10 Pro, I get this error:
C:\Program Files\MPC BE\madVR\amd_ags_x64.dll
Unable to register the DLL/OCX: RegSvr32 failed with the exit code 0x4.
I've installed the program many times on fresh Windows10 Pro installs, and only recently started getting this error with both the 32bit and 64bit versions of MPC BE.
I install the Advanced Code pack first, then MPC BE on Windows10 so I have a DVD play back solution, its just recently been failing...
Thanks for the report. It is fixed in the current releases.
