MKV with AC3 Audio - No audio unless AC3Filter is enabled
08-16-2012, 05:33 AM
Post: #31
RE: MKV with AC3 Audio - No audio unless AC3Filter is enabled
(08-16-2012 05:05 AM)guybrush06 Wrote: I have the same issue... MKV files with AC3 audio using SPDIF passthrough (Audio Bitstreaming set to AC3/DTS only) try using AC3Filter on the Config TAB, uncheck the box that is disabling AC3Filter then click the button [AC3Filter config] The window opens to the 'MAIN" TAB and you can select SPDIF in the upper left |
