MPEG & FLV Thumbnail problem
04-05-2012, 01:45 PM
I can't seem to get the FLV or MPEG thumbnails to show. I searched all the forum topics and did what you've asked other readers to do to get these to show and no luck so far. Uninstall/re-install, reset, check the FFDshow's codec in the 264 Tab. What else am I missing? These have always worked for me in the past. My OS is Windows 7 HP X64 and yes I have the add on with both set the same way. 32 bit default. I have the box checked at the bottom to use Shark's recommended settings.
04-05-2012, 02:15 PM
RE: MPEG & FLV Thumbnail problem
Uninstall the codecs and install current releases. x64Components addon __ 32bit Win7codecs
After installation, run each app with admin privileges. If after installation you do not have thumbnails, Go to the 64bit Config TAB and click on the button [Icaros Thumbnailing] |
04-06-2012, 01:01 PM
(This post was last modified: 04-06-2012 03:32 PM by julio99.)
(04-05-2012 02:15 PM)Shark007 Wrote: Uninstall the codecs and install current releases. x64Components addon __ 32bit Win7codecsI just wanted to let you know that I reinstalled again and it was still the same so I went back to the Icaros setting and realized that it was always activated so just by chance I de activated the Icaros and all the thumbnails just fell in line one after another so it was having Icaros activated that was giving me issues. Just a heads up for you and relief for me.Once I deactivated the Icaros and got the flv and MPEG thumbs. back I started losing the thumbnails for the new AVI's. Is there a way to get all back to full thumbnail or am I going to have to sacrifice one. I have a Windows 7 HP x64 laptop |
