ffdshow/LAV for .mkv
03-01-2012, 09:59 PM
Can I use ffdshow for video and LAV for audio in .mkv playback?
Maybe it's my imagination but ffdshow picture quality seems better but I like the LAV audio. If so, how do I achieve this please, and is it likely to cause audio sync problems? Thanks |
03-02-2012, 07:16 AM
RE: ffdshow/LAV for .mkv
Press [Reset All]
On the H264 TAB, select to 'Use FFDshow's codec' |
03-02-2012, 01:58 PM
(03-02-2012 07:16 AM)Shark007 Wrote: Press [Reset All] Thanks. One other query. I normally use the "sharpen complex2" shader, but it doesn't seem to be having any effect in my updated MPC-HC. I am using EVR custom output. Is that correct? And should I be ticking any of the pre-size pixel shaders? |
03-02-2012, 02:12 PM
I make no changes what-so-ever to the MPC-HC versions I release on my Tools page. They just work.
The settings you suggest, are your idea's not mine. I have no clue what effect they have, and am not interested in knowing. |
