ffdshow for AVI instead of
04-13-2012, 04:09 AM
I would like to use ffdshow as codec to get subtitles and to make use of media control. After some trial and error I got it working as desired for MKV. However AVI is still rendered using another codec (usually LAV). I selected Hali splitter and ffdshow wherever possible in the settings. How do I change that behaviour?
Michael |
04-13-2012, 06:20 AM
(This post was last modified: 04-13-2012 02:16 PM by HD-False.)
RE: ffdshow for AVI instead of
If you are using Windows 7 x64, could it be the "bug" in the Settings under "Config -->FFDshow Video config":
Set to "libavcodec"! Here are my full FFDshow-DXVA-Settings. AMD A6-3650 with HD6530 graphics * XP MCE 2005, Windows 7 x86 + x64 + 8 x64 * PowerDVD 12 + 13 |
04-16-2012, 09:40 AM
(04-13-2012 06:20 AM)HD-False Wrote: If you are using Windows 7 x64, could it be the "bug" in the Settings under "Config -->FFDshow Video config": Thanks!! That was the issue. You are my hero. I would have _never_ found that bug. |
04-16-2012, 03:04 PM
If SHARK007 is healthy again, he will fix this bug for sure!
