problem with avi thumbnails
04-06-2012, 07:00 AM
i have win7 with latest codecs + X64tools.
when i download a new video in AVI format, there's no thumbnail. at first in "ICARUS" I saw there's no listing for "avi", so i hit deactivate, added ".avi;" at the beginning , and then activate. the thumbnail appeared. but I have to deactivate and activate the icarus thing EVERY TIME because there is no thumbnail for NEW videos I download. Something else, the 2 new avi files are now in a network driver, and they had NO thumbnail. I deactivated and activated icarus and then 1 video had a thumbnail. I repeated the process again and then the other video also had a thumbail. needles to say I want the icons to appear all the time... Thanks. |
04-06-2012, 10:10 AM
RE: problem with avi thumbnails
Hi bizoot,
Icaros has never supported UNC paths (network directories), you have to remove ".avi" from Icaros' optional filetypes list, and let the default Microsoft handler thumbnail any files on your network drive. OS: Windows 7 Ultimate x64 |
04-06-2012, 02:12 PM
ok done that 4 now.
will wait for updates upon downloading new avi files. thanks. |
04-06-2012, 03:51 PM
(04-06-2012 02:12 PM)bizoot Wrote: will wait for updates upon downloading new avi files. Do you not get any thumbnails for newly downloaded avi files? Neither with Icaros nor MS' default handler?
04-07-2012, 02:06 AM
(This post was last modified: 04-07-2012 02:25 AM by bizoot.)
Post: #5
all my avi files that r already on my computer - have thumbnails now...
so there's no way 4 me 2 check id this works... OK, so I just downloaded a small avi file from a random website - to my desktop. the file had NO thumbnail! I hit F5 to refresh about 10 times. didn't help. opened icarus and pushed deactivate and activate a few times. didn't help. Only when manually adding avi to the icarus list - did the thumbnail appear (just wanted to check if the file even had a thumbnail to show). awaiting your thoughts. |
04-08-2012, 03:29 AM
Post: #6
(04-06-2012 03:51 PM)Xanashi Wrote:(04-06-2012 02:12 PM)bizoot Wrote: will wait for updates upon downloading new avi files. I DO get thumbs for all file types - EXCEPT avi files.... That's seems to be the only problem... |
04-08-2012, 06:04 AM
Post: #7
From what you have stated above, it sounds like avi thumbnails work when .avi is added to the optional filetypes list in Icaros,
but not when using Microsofts default handler. Since you need to thumbnail network files, try the following: Remove .avi from Icaros' optional filetypes. Merge the attached reg file to your registry, and test your files again. AviShellEx.reg (Size: 626 bytes / Downloads: 100)
04-08-2012, 06:23 AM
Post: #8
Well everything seems to be working just fine at the moment!
Thanks a lot 4 yr help! I'll keep on updating if problem persists. |
04-08-2012, 06:41 AM
Post: #9
(04-08-2012 06:23 AM)bizoot Wrote: Well everything seems to be working just fine at the moment! Glad to hear it, and please do. OS: Windows 7 Ultimate x64 |
