question about rmvb audio
02-05-2012, 04:37 PM
am sorry but how to adjust sound for rmvb files for media player classic and wmp?
02-05-2012, 05:28 PM
RE: question
use the volume control of the player.
02-05-2012, 05:31 PM
RE: question
no this is not what i meant the sound is not working properly in rmvb files
02-05-2012, 05:33 PM
RE: question
Do you have a current release of my codecs installed?
check your Windows folder for these files, if they exist, move them to some other folder for safe keeping. cook.dll drv33260.dll drv43260.dll pncrt.dll sipr3260.dll rmoc3260.dll reboot and test again |
02-05-2012, 05:44 PM
Post: #5
RE: question
(02-05-2012 05:33 PM)Shark007 Wrote: Do you have a current release of my codecs installed?yes i have the latest release v3.4.4 but i didnt find these files on the computer btw the sound in rmvb files was working with wmp in the previous release of the codecs but it wasnt working properly in wmp calssic |
02-05-2012, 05:46 PM
Post: #6
RE: question
(02-05-2012 05:44 PM)maldini_2010 Wrote: the sound in rmvb files was working with wmp in the previous release of the codecs but it wasnt working properly in wmp calssic read THIS THREAD for a possible solution You should use MPC-Homecinema from my tools page. It is preconfigured to use the installed codecs. |
02-05-2012, 05:58 PM
Post: #7
RE: question
(02-05-2012 05:46 PM)Shark007 Wrote:(02-05-2012 05:44 PM)maldini_2010 Wrote: the sound in rmvb files was working with wmp in the previous release of the codecs but it wasnt working properly in wmp calssic now it works perfectly with both after checking rm in the lav splitter and using the MPC-Homecinema from the tools |
02-05-2012, 08:05 PM
Post: #8
RE: question about rmvb audio
The next release will use LAV by default.
02-11-2012, 12:58 PM
Post: #9
The default setting works well for simple straight play back.
For my video watching, I use random access (e.g. Jump 5 seconds Foward/backward) a lot. But the LAV splitter just works not well to handle it, so I still have to disable rm from LAV splitter. I can see it get better in newer version(In Win7codecsv340 and before , it even cannot update a correct Iāframe), it still is not smooth enough for me use. |
02-11-2012, 01:01 PM
Post: #10
| RE: question about rmvb audio | |||
