HOT  LINKS
Login to account   Create an account
Login
Username:
Password:
Lost Password?
› Choose a topic below › ADVANCED Codecs
Conflicting MKV settings - Best of Both?
Threaded Mode
Durahl Offline
Junior Member
Threads: 1
Question  07-14-2021, 10:29 AM
Greetings!
On Win10 - I'm running into a conflicting issue between watching MKV HDR Movies on the Movies & TV App vs. subtitled MKV Shows using the Windows Media Player ( 12.0.19041.1 ).
Having the Disable Media Foundation for MKV unchecked in the 64-Bit Settings Application allows me to watch HDR Movies in the Movies & TV App but will cause the loss of Subtitles in the WMP.
With the Disable Media Foundation for MKV checked it's exactly the other way around - HDR Movies cannot be played anymore prompting an error, but Subtitles will again be played in the WMP.
Is there a way to have both work at the same time?
Alternatively:
  • is there a way to play HDR Movies in the Windows Media Player with HDR actually showing?
    As of now it doesn't ( noticeably less saturated than in the Movies & TV App - Typical nVidia RTX on/off effect ?).
  • is there a way to have Subtitles automatically be active in the Movies & TV App?
    The VAST majority of what I'm watching are subtitled Animes and manually turning them on in the App is getting old fast hence why I'm using the WMP for those where they're being displayed automatically.
Am I missing something? ?
Thanks in Advance!
Find
Shark007 Offline
Repackaging Specialist
Threads: 2
07-14-2021, 10:34 AM
You'd have to install the (preconfigured) MPC-BE player from my Tools page
and use that for all your viewing to have everything working in a single player.
Find
Durahl Offline
Junior Member
Threads: 1
#3
07-14-2021, 12:40 PM
Hmm... Not the solution I was hoping for, but beggars can't be choosers - Much appreciated!
I assume this is just a player and as such will still require a Codec Pac to read/run those files?
Find
Shark007 Offline
Threads: 2
#4
07-14-2021, 04:20 PM
The download I directed you to also includes a bundled hdr renderer.
As downloaded, it would rely on the codecpack for splitters and decoders
but it does have internal splitters and decoders that can be enabled forgoing the codecpack.
Find
  • View a Printable Version
Powered By MyBB © 2002-2022 - Theme by iAndrew © 2022
All trademarks discovered on this site are the property of their respective owners.
Privacy Policy - Shark007 © 2008-2022 - Legal Disclaimer
