11-18-2024, 09:21 PM
After downloading the latest version, I have no GUI(?)
I only see the shark007 titlebar icon and the X button (see attached image)
No GUI when running launcher
11-18-2024, 09:27 PM
Try changing the Display resolution.
To do so, rightclick the Desktop and choose Display settings (11-18-2024, 09:27 PM)Shark007 Wrote: Try changing the Display resolution. I am currently at 2560x1600. It didn't matter before what resolution I launched shark007 64-bit settings at, has this changed? EDIT: I am running a multi display setup EDIT2: Switched to 1440p, no difference in the settings app
11-18-2024, 10:23 PM
Close the Application.
Go to C:\ProgramData and delete the Shark007 Folder. Try again.
11-19-2024, 03:59 AM
I have seen this before. It does have to do with the multi-monitor system.
Have you tried dragging it to a different screen? Have you rebooted the system?
11-19-2024, 11:58 AM
I've released an updated application to deal with your issue, v18.8.1.1
To install it manually, with the GUI closed Doubleclick .\Tools\AutoUpdate.exe and it will install it To verify it installed, just hover the main executable, \Tools\Settings64_portable.exe and check the version. (11-19-2024, 11:58 AM)Shark007 Wrote: I've released an updated application to deal with your issue, v18.8.1.1 In an effort to give meaningful feedback, I did the following: - unplugged all displays - restarted - updated - ran it from Launcher64.exe no luck My system specs: Code: Host Name: UBERTEK-LAPTOPGPU: RTX 3080 mobile |
| Users browsing this thread: |
| 1 Guest(s) |
