No thumbnail for flv
No thumbnail appears for flv files.
flv is included in the list of filetypes; I tried to deactivate reactivate Icaros; also to deactivate reactivate thumbnailing inside Icaros.
Then what? Thanks.
Choose to clear the Windows Thumbnail Cache from within the Tools section of the Icaros GUI.
Then reboot your system.
(03-02-2025, 03:57 AM)Shark007 Wrote: Choose to clear the Windows Thumbnail Cache from within the Tools section of the Icaros GUI.
I tried to open 'Tools' but it is greyed out, wouldn't open.
I've cleared Windows Thumbnail Cache via Disk Cleanup, didn't help.
check that these keys do exist in the registry.
[HKEY_CLASSES_ROOT\.flv\ShellEx\{BB2E617C-0920-11d1-9A0B-00C04FC2D6C1}]
@="{c5aec3ec-e812-4677-a9a7-4fee1f9aa000}"
[HKEY_CLASSES_ROOT\.flv\ShellEx\{e357fccd-a995-4576-b01f-234630154e96}]
.reg   shellex.reg (Size: 630 bytes / Downloads: 230)
(03-02-2025, 04:58 AM)Shark007 Wrote: check that these keys do exist in the registry.
Can't run your file, nor open [HKEY_CLASSES_ROOT\.flv\ShellEx\ (attachments)
On the Help TAB, choose to [Remove ALL] and start with a newly acquired set of files from me (overwrite your existing files).
By using [Remove ALL], it will correct your issue.
The newly released file set (version 20.0.6) has several improvements that require a fresh start to get implemented.
(03-03-2025, 12:49 AM)Shark007 Wrote: On the Help TAB, choose to [Remove ALL] and start with a newly acquired set of files from me (overwrite your existing files).
Just no success :-(
Also, Tools and About are still greyed out.
Did [Remove ALL] complete successfully?
There should be a text information box presented when successfully complete.
Try using [Remove ALL] until it gives you this message box.
Attached Files Thumbnail(s)
(03-03-2025, 01:36 AM)Shark007 Wrote: Did [Remove ALL] complete successfully?
This time I ran Allow as administrator. Working fine now. Thank you.
